Slow sampling rate 9214
I am attempting to collect data using a compact DAQ 9174 with a 9214 high accuracy thermocouple module.  I am using 15 of the 16 available channels during my experiments.  I have used DAQ assistant to set up the module to collect at a rate of 4 Hz updating after each sample.  However, when I write my data, there are 4 entries per channel per second (which is what would b expected) but the values only update once per second (it shows the same value 4 times in a row then updates, shows that number 3 more times, update, 3 more times, and so on).  In the same while loop I am collecting data with a 9205 to read voltage inputs and am able to obtain 4 distinct vales per second with that module, Has this happened to anyone else?
(3,488 Views)
Accepted by topic author LabNewed
Hallo LabNewed,
Can you post some code illustrating your issue?
This way I can check what's happening in the code.
Are you using high-speed or high-resolution mode for your measurements?
If you're using the high-resolution mode, then this is expected behavior.
This is because the sampling mode is scanned (so it scans one channel at a time in a multiplexed way).
In high-resolution mode your bandwidth is 14.4 Hz (for 15 channels this is about 1 sample/sec), in high-speed mode this bandwidth is 80 Hz (>4 samples/sec for 15 channels.).
Please also take a look at the timing modes table over here: http://sine.ni.com/ds/app/doc/p/id/ds-314/lang/en
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(3,477 Views)
Thank you for your response, I was operating in High-Res mode.  I have made the switch and am now able to collect at my desired rate.
Thank you for your help.
(3,474 Views)
Hello LabNewed,
Can you mark this question as solved.
This way other people having similar issues will be able to fastly find the right answer.
Kind Regards,
(3,461 Views)
