search and split the string
Well the error you describe with your picture is quite obvious. If you paste this:
<pays> Finland </pays> <ville> Tampere </ville> <temperature> 17~C </temperature> <ensoleillement> Nuageux </ensoleillement> <date>5 mai </date> <time> 3:00 pm </time>
into the string control called "Input", and then press enter with the marker somwhere in that line of text, like this:
<pays> Finland </pays> <ville> Tampere </ville> <temperature> 17~C </temperature> <ensoleillement>(Marker was here when you pressed Enter on your keyboard)
the output will contain that Enter press on your keyboard. Like this:
" Finland Tampere 17~C
Nuageux 5 mai 3:00 pm "
The regex does not take care of this.
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
Message 21 of 22
(942 Views)
I have a similar kind of problem. I use LabVIEW 7.1 version.
I want to extract certain parts from a text file as a string. For example, I have something like below in a text file,
{"sendsms":{"version":"0","id":"OP13","priority":"0","message":"line 1 \nline 2 \nline 3","receivers":["+6582876403"]}}
Now, I have to extract the message "line 1\nline2 \nline3" alone; I know I can use the string subset function; but for that I need to specify the offset and lenght of the substring. What I want is to extract the message in the double codes after "message" in the above line; so the message may vary and due to this I cannot use string subset function which requires me to input the string lenght and offset. So, I need to extract whatever is inside that double codes. How to solve this? Kindly help.
Govind
Message 22 of 22
(898 Views)
