search and replace string formatting
I am trying to do a search and replace formatting of a string.
In the example I am looking for string "PASSED" but it must also start with usbflash and some number + PASSED.
I can't get the format to have a number from 1-99. The number of replacements should add up to 6 in this case. I have tried with \d for any number, and I also tried [1-99].
Message 1 of 10
(6,740 Views)
Please post the VI that you have tried so far along with the String input (In 2011 LV version please).
Message 2 of 10
(6,702 Views)
Try this attached file.   Robot Happy
Message 3 of 10
(6,692 Views)
You could use Scan From String with a format of %d.  That will read off the number and the remaining string should then be "PASSED".
Message 4 of 10
(6,678 Views)
Attachment - stringtest
My attachment is not uploading ! Smiley Frustrated
Message 5 of 10
(6,663 Views)
Try zipping up your VI and posting that.
Message 6 of 10
(6,642 Views)
Message 7 of 10
(6,634 Views)
I don't know why it's not working to upload ether ,zip or a vi?
I uploaded 2 images for the front panel and block diagram. Hope you can read it!
Message 8 of 10
(6,630 Views)
Accepted by topic author hasse
Right click on the Search And Replace String function.  There is an option to use Regular Expressions.  Then give this a try.
EDIT: You will need to set the Replace All input to TRUE.
Message 9 of 10
(6,627 Views)
Thank you crossrulz!
I had it set as regular expression - it was the plus sign that was missing.
Smiley Happy
Message 10 of 10
(6,619 Views)
