search 1D array
Hello guys,
I have a noob question.
I try to search with "Search 1D Array" function into an elemens of array.
In this elements I have same element in diferent rows.
If I run the "Search 1D Array" i receive only 1 index.
The question is:
How to find all indexes for that element ?1d array serch
Thank you for your help!
Message 1 of 12
(6,591 Views)
Hi a,
read the help for this search function.
Then use the 3rd input, which you have left unwired so far!
General comments/hint:
- clean up your BD, especially around the Search1DArray function: from your image it is unclear which wire is connected to which function input/output!
- Answer the question: Where should the search function start its search, when I want to find elements after the one element I already know?
Message 2 of 12
(6,585 Views)
Accepted by Adrian_A
Use a loop.  The Search 1D Array has an input for telling it which index to start searching at.  So you can use a shift register to tell it to start searching at the element after the last one found.
Message 3 of 12
(6,582 Views)
In this case i'd loop through all elements and build a new array of the selected ones.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 4 of 12
(6,562 Views)
Hello GerdW,
I have read the help for search function. I want to start from index 0 because I dont know where will be the element (in wich row of column).
If you see, I read the  column 4 of the table dbo.WeighingCleaning and, in this table I need to find in wich rows exist my "Cod DMC" element. This element could be in more rows.
After I find all the rows I will be able to prind this rows and comapre the data.
Thank you!
Message 5 of 12
(6,560 Views)
Hi a,
please answer the last question in my previous post!
(And read crossrulz's message carefully…)
Message 6 of 12
(6,549 Views)
I want to search the first element after the one element that I have found. (if I have understood  your question)
Message 7 of 12
(6,540 Views)
Hi a.,
Right!
But why do you start to search at index 0 all the time?
Message 8 of 12
(6,535 Views)
Thanks crossrulz
With your solution I have solved my problem.
Message 9 of 12
(6,534 Views)
Because I dont know how to do that.
How to start search after the index that I have found ?
Message 10 of 12
(6,531 Views)
