seach for path
Hi there,
I have a txt file with some configuration inputs to my labview application and i would like to kown if i can use a funtion to automatically search for that file path  wherever he is, or if i change my program and file to a new pc or location i want it to be able to repath without me manually inputing the path. Is it possible?
(2,528 Views)
Accepted by asnaev
What you ask for is possible through one of two mechanisms:
  1. The text file is always in the same relative position to the calling VI.  In this case, you can build your path from the path of the calling VI by stripping and adding directories.
  2. The text file is always in the same absolute position on the computer.  There is no searching.  You can vary this by platform by using the conditional compile structure and keying off the operating system.
You can do an exhaustive search of the entire file system, but you would probably not like the performance impact.  Option 1 is usually the best bet.
(2,509 Views)
I fully agree with DFGray.  Using relative paths is the way to go.  What you can do then is use the Application Directory node to get the location of the project/EXE and then build the path to your file.
(2,499 Views)
