scxi problem
I'm going nuts trying to figure this out. I'm new to Labview and NiDaq. I
have a P200 running Win 95, an at-mio-16-e2 board, Labview 5.1, nidaq 6.5
and a scxi 1000 with 1 1161, 2 1121 and 1 1120 modules. If I use the simple
analog in vi to get data from one channel I get what I expect. If I use a
multi channel input vi I get expectd data on the first channel in the list
but the subsequent channels are all at -10 volts. All of the gains are set
to 1 by the jumpers and in the channel wizard. The channel wizard sees the
scxi 1000. It seems like the board is not multiplexing the scxi modules. If
I build a vi with parelell loops and aquire data from different channels I
can get the expectd data from them. What am I doing wrong??
Posted from RemarQ, http://www.remarq.com/?a ****-
Search and Read Usenet Discussions in your Browser - FREE -
(3,439 Views)
I love my SCXI's, but they can be a little tricky to set up the first few
times. I would suggest very carefully checking the channel input strings to
the AI Start vi.
Ex : Ob0! SC1! MD1! 0:4
Also make sure that the modules are configured properly in NI-DAQ.
Unless you are an advanced SCXI guy, use multiplexed mode rather than
direct.
Good Luck and don't give up.
Charles Goulding wrote in message ...
simple
nel in the list
If
> -**** Posted from RemarQ, http://www.remarq.com/?a ****-
(3,439 Views)
I got it working. I feel a bit stupid because it turned out to be a simple
solution. The module connected to the at mio 16 board is THE one the cable
is connected to not A module in the chassis. Thanks for you responce.
(3,439 Views)
