04-21-2008 12:08 PM
04-22-2008 12:14 PM
Hi Cujo
Thank you for using our discussion forums.
The SCXI 1163R’s default jumper settings configures the module to be controlled with a Digital IO device. The PCI-6221 is an M Series MIO board, so you need to change three of the jumpers.
W2 should be set to M
W3 should be set to M
W4 should be set to A (Default)
W5 should be set to MIO
W6 should be set to S (Default)
Changing these jumper configurations will allow your 6221 to automatically detect your relay module.
Chris_K
