scrollbar for a waveform chart
Hi, I make the scrollbar visible in the front panel, but it's always gray out as shown below. How can I fix this? Thanks!
(5,227 Views)
Hi kwang,
switch off x axis autoscaling…
As long as the x axis is autoscaled (and so shows all available data) there is no need for the scrollbar!
(5,220 Views)
It's not autoscale. The chart only display the most recent data which is 3 minutes and 24 seconds long.
(5,205 Views)
Is it possible to share your code so we can see what exactly we're working with?
(5,195 Views)
Accepted by kwang305
Your Chart History property may be too small to display more data than that.  Try setting the X axis scale so it only shows 1 minute of data and your scroll bar will probably work.  If you need more history right click the chart and select Chart History Length...  Change that to a much bigger number.  That number is the number of data points it will buffer.  Its default is 1024 which is pretty small for most uses.
(5,184 Views)
So how many data point is in this 3:24 minutes?
How large is the chart buffer?
(5,180 Views)
It worked! I simply set the chart history length to a much larger number, 204800. Thank you so much!
(5,174 Views)
