scripting: insert existing typedef into a cluster
Using scripting, I can create typedefs and save them. I can create a control, open the typedefs and insert them into a cluster in the new control. But they are just clusters in the cluster and lose the connection to the typedef. I need to keep them as typedefs. I can do it manually by creating the cluster and dragging the typedefs in from a project, but can't get scripting to do it. Any brilliant scripters there?
Message 1 of 8
(5,410 Views)
This works for me:
How were you doing it?
Message 2 of 8
(5,370 Views)
Great start, thanks. But now I want to add several more typedefs into the same cluster. Here, the NewViObject won't work, so I was using the Move method for the typedef cluster, with the owner being the main cluster. This works but inserts them as clusters, not typedefs.
I think I can make it work with the Move, then Replace method - still working the flow. Fortunately this is in a system setup procedure and not where performance is an issue.
Message 3 of 8
(5,363 Views)
(Hate to reply to myself) but that worked. Akward, but works.
Using LV Scripting:
-Create Cluster
-Create Typedefs
-Cluster->Move typedef into cluster (set owner as cluster)
-Get refnum (Open VI Object Reference) to cluster formerly known as a typedef
-Cluster->Replace with path to typedef
I now have a cluster full of typedefs.
If there's a better way, please let me know.
Message 4 of 8
(5,360 Views)
... and I would suggest you mark your (previous) response as the "Solution", just in case someone else has the same (or related) issue.  Congratulations on your persistence and willingness to "experiment".
Message 5 of 8
(5,348 Views)
Accepted by brimcd
I don't know why you think that "NewVi Object" won't work; it works just fine:
Message 6 of 8
(5,343 Views)
I suspect that the reason you're not getting typedefs is that you are moving/copying a control from the FP of a typedef (which is not typdef'd) rather than moving/copying a control that is an instance of a typedef.
Message 7 of 8
(5,335 Views)
Pretty obvious why I didn't think it would work - cause I didn't think! Doh!
I Assumed it would create an additional cluster each time,  and didn't test it.
Thanks for correcting me
Message 8 of 8
(5,324 Views)
