screen resolution problems....
I have problems with the differents resolutions on xp  with my application.
I designed my application on lv7.1 on 800x600 and it ocuppies the whole screen, but if i test on another computer with 1024 x 768 pixels, the application is showed very little, i tried adjust the windows size , but i didnt get run well.
I would like if it is possible....  i would like the frontpanel go widen with the different resolution...
I attached 2 pictures.
Message 1 of 9
(4,237 Views)
picture screenshot
Message 2 of 9
(4,237 Views)
Go to File, VI Properties, select Window Size in Category, check Maintain proportions for different resolutions. You may not like how the fonts turn out.
Message 3 of 9
(4,233 Views)
Hi unclebump,
Thanks for the reply... but i tested it before...
The front panel widen to full screen but the tables or graph maintain the same size..
I send you a example, it runs well for 800x 600, but not for 1200x768...
Regards, Fonsi
Message 4 of 9
(4,219 Views)
Check the next lower box that says Scale All Objects on front panel as window resizes.
Message 5 of 9
(4,218 Views)
It doesn't run propperly... widen de bottoms and lines.
Message 6 of 9
(4,201 Views)
Hi Fonsi
take at look at the thread link  to LAVA:
http://forums.lavausergroup.org/index.php?showtopic=1717
It should give you some ideas /tipsSmiley Wink
chow
xseadog
Message 7 of 9
(4,174 Views)
Thanks xseadog,
Its very interesting... it solves any problems, but is not totally useful for me,, i should expect to future versions lv..
Regards.
Message 8 of 9
(4,152 Views)
You can change the screen resolution programmatically to match your front panel when your vi starts, and set it back to original resolution when you done.
Many games use this trick.
George Zou
http://gtoolbox.yeah.net
George Zou
Message 9 of 9
(4,127 Views)
