scanner webcam
I need help with a project.
I need to do a test program to compare images of a product x, and compare if it is as it should be. (in this case compare with a good product photo, right).
I need the labview get the image "on line" (real) and compare it to an image I put on, and tell me if it's the same image or not. if you have something different.
I can not begin the program, please! takes a lot of help ...
Thanks !!
Bruna
(2,763 Views)
This is exactly what machine vision systems are designed to do.
Might take a look at NI's smart camera line, I built a system a few years back that would look at an LCD and see if all the pixels were toggling.
Take a reference picture, then locate the points of interest and tell the camera to compare the two.  Can do any number of things including toggling external relays, sending commands to other instruments, or simply turning on a red light... all right within the camera itself.
(2,753 Views)
I had found this tool in labview ... but I have a hard time understanding it .... could you please send me an example to see how I set up a photo to compare with a real image?
Please, I need help ...
i'm lost... 😞
Thanks !!!
(2,741 Views)
