scan rate using hardware timing.
How can I set the scan rate accurately to 1000 Hz using hardware timing.
(2,665 Views)
Wire 1000.00 to the Scan Rate input of the AI Start VI. That will set up the scan clock on the DAQ board to run at 1000 Hz. Note that it will only work on NI DAQ boards.
Daniel L. Press
PrimeTest Corp.
www.primetest.com
(2,665 Views)
