scan from string
sorry about that. is this okay?
Message 11 of 23
(1,954 Views)
Hi Gekides,
now you correctly downconverted those VIs. But now you missed to include some default data for your "body" indicator…
The main point is: I don't want to re-type all that html text shwon in your pictures!
Message 12 of 23
(1,949 Views)
<!DOCTYPE HTML>
<html>
<meta http-equiv="refresh" content="5">
21.77
degreescelsius604
sensor value2.95
sensor voltage<br />
2.23
Volts46.06
%<br />
0.10
Volts0.39
m/s<br />
2.51
v2.54
v5.33
kPa<br />
<br />
</html>
Message 13 of 23
(1,935 Views)
Hi Gekides,
you really should talk to the guy who created that HTML server - or beat him…
Message 14 of 23
(1,923 Views)
thanks. but the values that i will need are 21.77 degree celcius, 46.06%, 0.10m/s and 2.51kPa. is there anyway to extract only those reading because i will need them to be displayed on a numeric indicator?
something like this
Message 15 of 23
(1,907 Views)
You have an array, so just use index array to get out the indices that you are interested in.  Then convert them to numbers and send them to their respective indicators.
Message 16 of 23
(1,895 Views)
i can't replicate those and i don't quite understand how it works
Message 17 of 23
(1,886 Views)
If you don't understand how to index an array, you need to stop right now and take a couple tutorials or the free basic classes.
Message 18 of 23
(1,882 Views)
a bit of index array is ok. but i don't know what are those? can i have the vi of that so i can slowly understand please??
Message 19 of 23
(1,868 Views)
Hi Gekides,
my solution will give you an array of values and all you need to use is IndexArray to pick your needed values…
What do you mean by "those"?
Message 20 of 23
(1,847 Views)
