how can i get more decimal point.
when i got fetch waveform data from oscilloscope(model TDS5104), i want more decimal point.
for example, oscilloscope output a point which print is 1.5214mV , but i fetch the point which is 1.52 by labveiw progam.
i used a attached instrument driver.
thanks.
Message 1 of 11
(4,767 Views)
Right click on the indicator and look at your options.
Message 2 of 11
(4,752 Views)
You did not attach anything, but you can change the display format of any indicator (or control) to suit your needs.
You did not attach anything. How are you displaying the value?
Message 3 of 11
(4,751 Views)
sorry this is attatched.
Message 4 of 11
(4,729 Views)
i dont know why do not upload attach
Message 5 of 11
(4,721 Views)
Hi redsna,
maybe you have the same problem as others describe here. Seems to be hard for Lithium to support FireFox, but you will find workarounds following that link…
Message 6 of 11
(4,715 Views)
this is attached
Message 7 of 11
(4,712 Views)
Please explain which indicator is giving you trouble.
Message 8 of 11
(4,696 Views)
Y in waveform data (step6)
Thank you
Message 9 of 11
(4,679 Views)
Accepted by topic author redsna
The waveform Y is DBL, so it internally has plenty of resolution. The number of displayed digits is just a cosmetic property and can be freely chosen.
How do you tell that the resolution is less? I cannot tell from the VI you have attached. If you want more digits showing on the Y scale of the graph, just change the formatting.
Message 10 of 11
(4,668 Views)
