scan array and sort
In the attached VI, I would like to extract the first 50 points, then next 50 and so on (from the attached file), and build up an array as shown in the image file.
Any help will be greatly appreciated.
hiNi.
(4,216 Views)
Accepted by topic author hiNI
To improve memory use in case of larger file use the in place element structure instead of the replace array subset functions.
Ben64
(4,199 Views)
I was hoping to solve this without a loop...
Jim
(4,198 Views)
I think loop are unavoidable, the goal is to use just one!
Nice solution Jim.
Ben64
(4,195 Views)
I tried to go for no loop. I wasn't able but I got down to this.
Ben64
(4,189 Views)
Hello Jim,
Where do I find the left bottom most block in the while loop?
hiNi.
(4,178 Views)
Array Palette -> Matrix sub Palette -> Matrix Size
(4,172 Views)
