scan array and sort
In the attached VI, I would like to extract the first 50 points, then next 50 and so on (from the attached file), and build up an array as shown in the image file.
Any help will be greatly appreciated.
hiNi.
(4,263 Views)
Accepted by hiNI
To improve memory use in case of larger file use the in place element structure instead of the replace array subset functions.
Ben64
(4,246 Views)
I was hoping to solve this without a loop...
Jim
(4,245 Views)
I think loop are unavoidable, the goal is to use just one!
Nice solution Jim.
Ben64
(4,242 Views)
I tried to go for no loop. I wasn't able but I got down to this.
Ben64
(4,236 Views)
Hello Jim,
Where do I find the left bottom most block in the while loop?
hiNi.
(4,225 Views)
Array Palette -> Matrix sub Palette -> Matrix Size
(4,219 Views)
