scale of 2-D array of knobs.
Thank you Altenbach that helped me to set the range for a single numeric array .Now What Iam trying to do is set the data range limits programatically from the defined table on the block diagram. So for this i created references for each numeric array and tied them to the  build array. And created a property node to that build array.But I dont know how to acces each individual numeric array  from that point and set the limts.Can you also pls help me at this point.
Thank you,
Shanth.
Message 11 of 12
(625 Views)
Message Edited by Ravens Fan on 07-30-2009 02:04 PM
Message 12 of 12
(616 Views)
