sbRIO-9627 does not display CAN in the project
I am engaged in doing Hardware in the loop testing. For this goal, I would like to implement communication over CAN BUS on my sbRIO with ECU.
I have software packages such as NI-XNET and NI-CAN installed. There is an RMC card with DIO connected to my sbRIO, I also have a card with Analog Input Output.
I am using Labview 2019 32 bit.
The problem is that neither in the project nor in NI MAX does not detect my CAN connector (File 1 and 2).
I only have connectors detected by NI-VISA, which doesn't help me much. How do I go about configuring this? I looked through the sample programs, but they require having this CAN connector.
(1,250 Views)
To use the onboard CAN of sbRIO-9627, you need NI-Embedded CAN for sbRIO driver. Reference: Using CAN with NI CompactRIO Single‐Board Controller (sbRIO)
https://tmesystems.net/
(1,226 Views)
