sawtooth waveform peak detektion
Hi all,
I recently encountered the following problem:
I have a sawtooth waveform sampled from an oscilloscope and I need to
detect the falling edge of the sawtooth signal.
I first thought of using the "peak detect" function, but this fails
since there is some jitter on the signal and sometimes an even larger
peak after the falling edge, which "peak detect" will find.
Any mathmathical interessed LV's around, who know how to find the
falling edge of a sawtooth, in spite of jitter and later peaks ?
Thx
Jürgen
Jürgen Dachs
Infineon Technologies
email: Juergen.dachs@infineon.com
(7,103 Views)
Yep I have a similar problem - this is what I do:
(I presume your sawtooth is in an array?)
If your sawtooth samples is N, make a new array with n+1 samples
copy the original to the new array right shift it one place. Add an
empty element to the begining of the original array - then subtract the
two arrays. This gives the difference between successive samples, the
falling edge should show up quite clearly. Then do a max value of the
difference array - take a value 50% down on this and produce a new
boolean array with a zero value if less than 50% and a value of one if
greater than 50%. You *should* get a pulse waveform whose peaks coincide
with the falling edge (you may have to watch the sign of the difference
array).
I do this to measure the frequency of a rounded squ
are wave with DC
shift - works for me!
Good hunting!
In article <37394641.2467@stud.fh-regensburg.de>, juergen.dachs@stud.fh-
regensburg.de writes
>Hi all,
> Thx
> Jürgen
>Jürgen Dachs
Pete Barnes
(7,103 Views)
Try an algorhythm based on first derivative and threshold
regards
Antonio
Novakon Srl
Div. Sistemi Medicali
(7,103 Views)
C
Jim
(2,919 Views)
