saving to spreadsheet after stopping a while loop
I am writing a program that generates an analog signal, transmit it to Schmitt trigger, then puts out the original signal and the trigger signal into a waveform chart. It then must output a series of data as a spreadsheet file after the loop is stopped.
I've gotten the thing to output a waveform chart and stop it with a button, but I can't output it as a spreadsheet file. What should I do? I've arrayed both sets of output into 1D array, but after pressing STOP it won't do anything. If I stick the save to spreadsheet vi into the while loop, the save prompt triggers, but after only the initial iteration.
The "noisy analog" is a signal generator using a function, which is rendered into a subvi and imported into untitled 1.
(2,906 Views)
You did not attach a VI with the write outside the loop so it is impossible to say what you did incorrectly. The current VI creates a new file each iteration so that will not save anything except the last value. You will get the prompt for a file name each iteration
The simplest thing is to pass the array out of the loop and enable auto-indexing on the exit terminal. Simply right click on it and select 'Enable Indexing. Or, fix the write function when it is inside the loop to not create a new file and not prompt for a file name each time.
(2,895 Views)
I've passed the array to the outside of the loop, enabled indexing, but again it does nothing. Any ideas? I've also tried linking into a select but it really just refuses to write to spreadsheet. 😞
(2,884 Views)
Accepted by topic author GabrielleD
You've got a stop function inside your subVI. No point at all in having that.
(2,870 Views)
It worked! Thank you!!!!
(2,867 Views)
