HyperTrend Control Could not be loaded
I'm writing an application where I use DSC module and NI HyperTrend control to drow trends from Citadel DB. When I comile my application and install it on my PC (where I develop application) there is no problem to view trends with HyperTrend control. When I install my application on target PC and try to start VI where HyperTrend is placed there is an empty square with message inside "Control could not be loaded". How can I "install" HyperTrend control on target PC.
(3,661 Views)
If your program works on the computer it was written, but not on a target PC, I can almost guarentee it is a problem with dependencies.
Did you create an installer for your program, or just an executable?
I would just double check that you included the control when you built the program installer.
Cory K
(3,649 Views)
I'm new to labview and I too have this problem.
I see that this is a problem for a lot of people. I have tried following all howtos I could find here to solve it but I'm still unsuccessful.
I liked the idea of making an installer that contains everything needed.
Now the question is what is really needed, and how do I include it?
I miss a good tutorial that shows me how I access historical data from a client computer. If anyone could point me in the direction
of one it would be really appreciated.
In short, what do I need to do when configuring the installer to include everything needed for hypertrend to work?
Thanks in advance.
oysteine
(3,360 Views)
Is this helpful: http://zone.ni.com/devzone/cda/tut/p/id/6579 ?
Peter
Peter Vago
(3,343 Views)
Peter thanks,
I will check it out and let you know if it helps.
Cheers,
oysteine
(3,337 Views)
I have the same problem and can not find solution.
If i solve it i let you know
por el poder de Grayskull
(3,321 Views)
