saving cluster of different data types to a file
I use LV 8.6 SDK. I need to save clusters of different data types to a file on a disk, row by row.
To be specific: I have a program that performs various investigations on a signal collected by DAQmx. Each time the quality of the signal is not in a specified boundaries, i get an indication. It is a cluster of time stamp, string, dbl, and Boolean. The program is supposed to run for few weeks in a row so there can be a lot of these indications. I expect to have around 200 000 rows a week (Altogether, divided into several groups).
I thought about TDMS but I am not able to save such a cluster. And I would like to save it as tdms cause i could divide the data to different groups. I also thought about data base but that would be the first time i use db and I really do not  have time to learn that now.
I know it is possible to change some of the data types to others, ex Boolean to 0-1, but i need a string and a time stamp there.
Can someone advise me which data format should I use? Which one is the best one in this situation?
Thanks in advance
handre
(3,550 Views)
If you do not need to access data from another application (other than Labview) you can just save it as a binary file.
It is the best choice (for me).
I made an example with one cluster. You can replace that with an array of clusters, of that data type.
(3,529 Views)
Thanks for your answer!
I forgot to add that I would like to use the data not in LV afterwards for investigations. Is it possible to open binary files for example in Matlab?
Moreover, I like tdms because I can write and read data at the same time. It is probably not possible in binary format,  isn't it?
handre
(3,513 Views)
If you want a TDMS file , one solution is to convert all your data to strings.
You will have a 2D array which it can be stored in TDMS.
Each row will be one measurement.
(3,478 Views)
