‎08-20-2009 05:30 AM
Hi to everybody, I am trying to build an installer and in the middle of the process it is stopped showing the next message: "An error ocurred while saving an activeX object".
Can anybodody tell me why can it be happening?
I am using LView 7.1.1.
Thanks in advance
jm
‎08-20-2009 07:01 AM
‎08-20-2009 07:05 AM
Yeah, I think so.
More information about the error:
"Fatal internal error: memory.cpp, line 1038
Labview version 7.1.1"
Thanks in advance
jm
‎08-20-2009 07:12 AM
‎08-20-2009 07:56 AM
Thank you very much.
I think the proble can be solved in this way, but my problem is that I do not know the library/ies I need to convert. I do not have any info about it in the error message.
jm
‎08-20-2009 08:08 AM
Can you elaborate a little bit
‎08-21-2009 03:16 AM
Hi again,
what I want to say is that I think I should know the ".dll" files that I have to convert. But my problem is that I do not know which file I have to select to be converted. What I say is I do not have any information related to this in the error message.
Thanks for your help
jm
