saved data in string on front panel
Accepted by tominsek
Hi Tim,
@tominsek wrote:
So how can i put for example string of database name to cluster?
if i understant all parameters need to be in cluster and connected to my shift register in the state for example (''read parameters...'')
Yes.
You need to edit that type definition!
@tominsek wrote:
is it possible that you make me only for visa com port, what you wrote in previous message. Just so i can imagine, for other parameters i will do it by myself
Like this:
Message 31 of 35
(406 Views)
Hi bohanvo2,
Do you maybe have some example of how i could do that for my project?
my project is almost done, only thing that is left are this thing that values must stay the same of how you edit them before closing application.
Message 32 of 35
(386 Views)
Hi Gerdw,
I will try like that tommorow...
hope that this works, because is the only thing that i must to do in my project to be completed
Message 33 of 35
(385 Views)
Write the variables on the INI file when the program exits.
Message 34 of 35
(376 Views)
Hi Tim,
Definitely no, that's not "the only thing"… 😄
Message 35 of 35
(351 Views)
