save frame when pressing the button
Thanks! the 'path issue' solve that particoular problem 🙂 thanks!!!!
yes I know that I'm overwriting, I though to  start with 1 and then move forward..now that I can save a single image, I 'll work on the 'sequence' .. any idea?
Thanks again for the help btw!
Message 11 of 16
(876 Views)
Depending on the "frames per second" the AVI should have, it is probably easier to extrace specific images from the AVI as postprocessing offline.
If you want to do it "online", you have to use some counter to generate unique filenames.
Norbert
Norbert
Expert: Geometry
Message 12 of 16
(874 Views)
yes I was thinking at some counter..I'll try and ask again if in trouble (so I'll post again 🙂
thank you!
Message 13 of 16
(872 Views)
I found this solution:
https://forums.ni.com/t5/Example-Code/Create-unique-filename-by-auto-increment-path/ta-p/3503548
the problem is that it add a number at the end of the filename just once..is there a method to 'feed' the code with the new name everytime so that it will add a number whenever needed?
Thanks!
Message 14 of 16
(864 Views)
Not without implementing the logic on yourself.....or finding code someone published which solves this.
In general, this task is rather easy IF you have a good idea on where the base name shall be derived from.
Norbert
Norbert
Expert: Geometry
Message 15 of 16
(860 Views)
Accepted by topic author Elena_vsc
here the solution 🙂
Thanks for your help!!
Elena
Message 16 of 16
(857 Views)
