save data from LabVIEW2010 to Excel (Win7) with the format xlsx
Then you need to check if the file exists first using the Check if File or Folder Exists VI. If it exists, use the Save method for the workbook class. If it doesn't exist, use the Save As method for the workbook close. For the Close method wire a False to the SaveChanges parameter.
All of the documentation for the Excel ActiveX interface can be found on MSDN.
Message 11 of 12
(1,384 Views)
Accepted by topic author zäpfle
Spoiler
Thanks all, special thanks to smercurio_fc
I modifyed the "Write Table To XL_Test1 MOD.vi" a little bit and the result is the best solution for me.
best regards zäpfle
Message 12 of 12
(1,371 Views)
