save data for each channel in a separate tdms file
Good morning ,
I acquire 2 parameters and I need to record in separate t dms files I acquire continuously, I tried to code it like this but it doesn't work I record no data and I understand not why
What is the most optimal way to save in separate files?
thanks in advance
(560 Views)
Good morning,
"It doesn't work", can you specify the problem in more details ?
- is no TDMS file created ?
- are the files empty ?
- do the files not have all data ?
- etc.
If files are created, can you send us an example ?
(557 Views)
