04-06-2016 08:04 AM - edited 04-06-2016 08:05 AM
Dear All
I buy this
And I thougt that it installs a driver to control it by COM port, but not. Seems that needs the create or write a dll library (I had never done that)
In attach is the data with dlls and a excutable to open and close the relay and it works, but I would like to put it working with labview.
Can someone help me?
Best regards
cpalha
Solved! Go to Solution.
04-06-2016 03:40 PM
Hi people
Seems there is no solution....I am looking for all internet and no labview examples....
In attach I add more information
Best
cpalha
04-07-2016 03:39 AM
Hi Cpalka,
Does it answer to VISA request?
Jovan
04-07-2016 04:01 AM
Even though you didn't include the DLL, I'm guessing that they provided one for you? If that's the case, you can use the Call Library Function node in LabVIEW to call the functions as specified in the header (.h) file - you might even be able to use the header file and DLL with the 'import shared library':
Did you say that it shows up as a COM port in device manager? If that's the case - you might also be able to find out what the serial commands are (ask the manufacturer for the documentation) and then you can use NI-VISA in LabVIEW to write the commands to the serial port.
04-07-2016 07:22 AM
Hi Sam
Thanks for your help.
No this is not appear has a COM port, if yes as I thought I use the visa.
I will try import the dll file (I never done it before) to see what will appear ??????
Once again manya thanks
cpalha
04-07-2016 07:48 AM
04-07-2016 08:14 AM
Hi Sam
I creat this project with the dll and h files.
But seems before create I need to add some information to the commands as the bumber o chanel (Isuppose it is 1) because i only have 1 relay.
Other thing is the Device name mine is AHFV6
See the other picture from control panel, it appears when I conect the usb cable
Best
cpalka
04-07-2016 08:20 AM
The manufacture is from ebay.
A send some files, a exe to control, *.dll and *.h files
best
cpalka
04-07-2016 09:51 AM - edited 04-07-2016 09:52 AM
That price is quite attractive. But in the future you may want to use some standard hardware like an Arduino and a relay shield. There are currently two toolkits for LabVIEW where commands are sent and the Arduino reacts and sends a reply. This is LIFA which is older but works fine, and LINX which is newer and has more hardware support. Both have standard LabVIEW VIs where you can do things like read DI, set DO, read AI, set PWMs, perform I2C and SPI communication, and interface with various sensors and control various equipment.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
04-07-2016 11:55 AM - edited 04-07-2016 11:56 AM
Hi Hooovah
I am an engineer and I need to make some solutions that there no so easy to do.
I have a board ni9237 for reading 3 load cells and one encoder (a reduce de 5v to 15mv and then I get pulses with 15mv) to calculate speed of a slow motor and everything works.
I only need now a automatic start for the motor thats why I buy this and with visa and pressing only one button in labview I start the motor and the saving data, but it dont uses COM port.
I know the system you talk about but sometimes we need to do cakes without eggs 🙂
Thanks a lot
cpalka
