save Video on USB Stick connected to myRio
I wanna save a Video that I make from a Webcam, which i have connected via a USB Hub to myRio, on a USB Stick that is also connected to this USB Hub. This programm works just fine on my Computer, but when I upload it to myRio and change the Path to the USB Stick the programm just creates a new avi and writes nothing in it.
(1,413 Views)
Hi Spurbrünette,
Does the myRIO even support that webcam?
Are there any errors in the IMAQ camera functions?
(1,409 Views)
What Cameras Are Supported on NI Linux Real-Time Targets?
On Real-Time controllers running NI Linux Real-Time, USB 2.0 cameras that are USB Video Class (UVC) compliant are supported. Please check with the camera manufacturer to see if you have a UVC camera. To use a UVC camera with your Linux RT target, you need to perform a custom software installation on the target and install the component USB Webcam Support.
You should wire the error cluster indicator to capture any possible error.
https://tmesystems.net/
(1,394 Views)
Spoiler
Yes, the myRio supports the Webcam. A stand alone stream from the Webcam to my Computers Display works without a problem.
(1,384 Views)
