Scp command for enable and setting up trace for power sensor
While working on power sensor (U20221XA) using Aglient U2000 drivers i was trying to setup trace using built in vi from aglient U2000 drivers but i was unable to setup trace for measuring Rise and Fall time. So Can anyone suggest me scp commands for same.
(804 Views)
Have you tried searching the programmers manual for the SCPI command? https://www.keysight.com/us/en/assets/9018-06011/programming-guides/9018-06011.pdf
Santhosh
Soliton Technologies
(802 Views)
