sampling rate
Spoiler
I have got it thanks a lot but why did you changed using write to text file.vi instead of using write to spreadsheet file.vi? is that necessary to use only write to text file.vi? or any method will do the same work? but when i was using write to spreadsheet file.vi for same purpose, it didn't go well it writes the data about almost 200 samples for 10 second, can you tell me the difference?
Thanks again,
Dinesh
Message 11 of 12
(576 Views)
The Write To Spreadsheet File opens and closes the file.  But since we are wanting to constantly write data, it it a lot more efficient to open the file at the beginning and close the file at the end.
Message 12 of 12
(572 Views)
