runtime menu crash
In one application I have a runtime menu which is dynamically changed. When a option is not available, the menu point is dimmed. Now I found out, that LabVIEW crashes every time when the runtime menu is opened while the change occurs in the program.
Is there a way to avoid this? Otherwise the whole option to change the runtime menu dynamically would be worthless..
Best regards
Dermot
(2,868 Views)
Which LabVIEW version are you using?
Could you attach an example that demonstrates the problem?
Jochen
National Instruments Germany
(2,851 Views)
Hi
just now by looking at it a second time, I found the solution.
In a early version of the program I added and deleted the runtime menu tags dynamically. When the runtime menu was opened during a delete action, LabVIEW 7.1 crashed completly.
Now I just dim the tags that are not available, that means I only change the properties of the tags and the program works just fine.
Thanks and best regards
Dermot
(2,845 Views)
