runtime error when adding a softmotion axis
Hi Mychal,
That's great that we're on the same page. I had seen the post about adding the trajectory generator functions to the 2011 palette, but when trying this I couldn't get the example code to open (It said I needed to install the softMotion module, though it was already installed). Is there any way I can get 2011 to open these examples in the labVIEW example finder?
Many thanks,
Matt
Message 21 of 25
(1,081 Views)
Hi Mychal,
Thanks for all of your help. I have reinstalled labVIEW 2011 and softMotion 2011, while copying the 2010 examples to another directory. All examples now work, I can add softMotion axes, coordinate spaces and tables to my projects and I still have access to the trajectory generator. Thanks again for all the help.
Cheers!
Matt
Message 22 of 25
(1,076 Views)
Hi Matt,
That's is great news! Good luck with your application!
Mychal F.
Applications Engineer
Message 23 of 25
(1,071 Views)
Hi Mychal --
I'm also running into this issue on the same software versions mentioned before. I am running LabVIEW 2010 SP1 and I'm evaluating SoftMotion 2010 SP1 but I cannot upgrade LabVIEW for compatibility reasons. Have the software engineers found a workaround or patch to fix this run-time problem?
Thanks.
Richard B.
Characterization Engineer
Texas Instruments
Message 24 of 25
(998 Views)
Hi Richard,
I looked up the CAR filed for this issue, 336637, and it seems it was fixed in SoftMotion 2012.  Unfortunately there seem to be no work-arounds that involve keeping LabVIEW 2010, so I am afraid that if we cannot upgrade, we might be a little out of luck with this issue.
Also, the forum post you have resurrected is over two years old.  In the future, feel free to make a new post about this that references this thread instead of replying to such an old post.
Julian R.
Message 25 of 25
(981 Views)
