runtime editing in multicolumn listbox
Dear All,
         I want to edit cell of multicomumn listbox at run time. Any one guide me to do this.
---Vishnu
Message 1 of 13
(12,202 Views)
You need to use event structures. Have a look at the attached image.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
Message 2 of 13
(12,200 Views)
Dear Adnan,
          Thanks for help. But the solution given by you is application to LV8.6. I have LV7.0. Is there any way to have runtime editting of multicolumnlist box in LV7.0.
--Vishnu
Message 3 of 13
(12,158 Views)
maybe this will help...
.......^___________________^
....../ '---_BOT ____________ ]
...../_==O;;;;;;;;_______.:/
.....),---.(_(____)/.....
...//____//......
..//____//......
.//____//......
Message 4 of 13
(12,144 Views)
This works Great in one of my listboxes - it has 6 columns.
However, my 2nd listbox has only 2 columns (no row headers), and it causes the 2nd column to jump to the left,
and shows 3 blank columns to the right!
What is going on, and how can I correct it?
G
Message 5 of 13
(10,896 Views)
Thanks. I solved the problem.
Message 6 of 13
(10,575 Views)
for anyone else that runs into this problem, it stops if you set the number of columns to whatever the appropriate number for your application is. I had a 2 column listbox that was jumping to the left when I use the "Edit Pos" property. It stopped jumping after i set the "Number of Columns" property to 2
Message 7 of 13
(10,332 Views)
Works flawlessly.
Message 8 of 13
(9,167 Views)
Thanks!
Message 9 of 13
(9,164 Views)
How to add element Point to row column in property node.
As that is not available for me.
Sathish Kumar A
Certified LabVIEW Architect (CLA)
Message 10 of 13
(7,334 Views)
