Exporting waveform data to excel
I am trying to export waveform data to an excel sheet.After exporting, under the time plot I am getting values in the multiples of 8 as it can be seen in the screenshot that I have attached. Is there anyway, can I get the time plot values on a linear scale (i.e, 1,2,3,4,5........).Your help is much appreciated.
(3,873 Views)
Hi suji,
maybe you should also show the VI you use to create this result in Excel!?
How can we provide help when all you show is an image of sume numbers from an Excel sheet?
Yes.
(3,869 Views)
@GerdW wrote:
Hi suji,
Yes.
Actually, I am doing real-time FFT analysis. From the output waveform that I am getting, I am exporting that data by right-clicking on the waveform Export>Exporta data to excel.
(3,863 Views)
Hi suji,
Then you use a functionality built into the graph. You can use it as it is right now.
But when the built-in function doesn't fit your needs you need to program your own way of saving the data!
There are ready-to-use functions to save waveforms to a spreadsheet file…
(3,855 Views)
My NI Crystal Ball has mis-functioned and is not allowing me to open your VI and see how you are writing the data.  If I had to guess (what alternative is there?), I'd say you are writing a variable that increase by 8 each time you write (but you already knew that ...).
Attach your VI.
(3,839 Views)
