running multiple user interface events
I created a LabView VI using the "User Interface Event Handler" template.
While one command (event) is executing, I would like to be able to process and execute additional user events.
For example, button 1 executes a power interrupt by sending a power off command to the remote device, waits 10 seconds, then sends a power on command.
While I am waiting 10 seconds to execute the ''power on' command, I'd like to be able to run 'button 2' and so on.
Thanks for your help...
(3,382 Views)
Accepted by jonwang
This is often done by having another loop that handles the "long" events.  Use a queue to send the message to this loop.  Then the event handling loop can service the other events.
Another option is to dynamically call a VI to run asynchonrously so that its running happens in parallel with everything else.
(3,373 Views)
Thank you.
(3,366 Views)
