run time engine
Hi all
I have instulled LV7.1 & 8.5
When I in LV 8.5 run Web Publishing tool I have error : "Failed loading Labview Run-Time Engine version 8.5".
What can I do?
Regards
Iskander
Message 1 of 9
(5,485 Views)
Hi Iskander,
are you sure the Run Time Engine 8.5 is installed?
Mike
Message 2 of 9
(5,474 Views)
Are you sure you have LV 8.5 installed and not 8.5.1? Check the Help->About LabVIEW Dialog Box and see the current version at the bottom right corner of the dialog box.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
Message 3 of 9
(5,470 Views)
Hi
I am working in 8.5
Regards
Iskander
Message 4 of 9
(5,466 Views)
Hi Iskander,
There are two places that LabVIEW will search for the Run-Time Engine. Please check that your RTE 8.5 is in either
 a) The directory specified by the registry key: HKEY Local Machine\Software\National Instruments\LabVIEW Run-Time\8.5
OR
 b) The default install location: Program Files\National Instruments\Shared\LabVIEW Run-Time\8.5
If the RTE is in neither of those locations, copy it over to one of them.
O. Chiu
Message 5 of 9
(5,421 Views)
Hi O. Chiu
The  two places HKEY & Program Files are instulled.
My be Run Time LV 7.1 to mix  Run Time LV 8.5.
Regards
Iskander
Message 6 of 9
(5,391 Views)
Iskander,
Are you able to use the Web Publishing Tool with LabVIEW 7.1? It sounds like a link between the run-time engine and LabVIEW was lost when you had installed version 8.5. You may have to uninstall and reinstall version 8.5.
Message 7 of 9
(5,330 Views)
Dear Olivia.
Thanks for the answer
and excuse me for the silense.
I will be try.
Regards
Iskander
Message 8 of 9
(5,279 Views)
Hi friends
I am Joseph from London.  You should concern with developer.
Joseph
Message 9 of 9
(5,270 Views)
