Programmatically add password to password cache
Is there a way to programmatically add a password to the password cache? My build process requires some vi passwords to be known. Since the build takes some time I would like to set them at the beginning so the build can run from there without user interaction.
Any Ideas?
(3,529 Views)
Accepted by topic author Xerxess
Hi Xerxess,
you can use the invoke node "set lockstate". There is also a private method "Pwd.Add to Cache".
Mike
(3,524 Views)
Great! Thanks for the hint!
(3,504 Views)
