rube classic
Just started a new job developing new systems and cleaning up existing systems.
Came across this beauty in their archives.
This is but a small snapshot of a much more horrifying display.
The basic premise is this: tester is running four test systems in parallel.
So the LV coder made individual case structures to contain every control on the front panel.
Then put them all in a for loop to update them all in sequence.
This same process was repeated throughout the entire VI. It is a marvel to behold!
Imagine the (wasted) time and dedication it took this person to create a case structure for every control on the front panel, and populate each one with a local variable!!
Boggles the mind.
(3,025 Views)
Looks like the programmer came from a text-based programming background. Feel free to post this in the Local Variables thread or the Rube Goldberg thread. It's a candidate for either one.
(3,018 Views)
But even from the old text-based background on initializing everything directly, the multiple case structures don't make sense. Even the text based code would look stupid:
for i=0 to 3 do
  // Control1
  case i
     0: control1_1=0
     1: control1_2=0
     2: control1_3=0
     3: control1_4=0
     // don't forget to add another case if there is one more test station
  end
  case i
  //ok, let's initialize the next control....
Felix
(3,006 Views)
