LV6.02 Driver for Agilent E5071B?
Is it possible to convert the LV7.0 driver into LV6.02 for Agilent E5071B?
Here's the link: http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=001CE83736F3674BE0440003BA7CCD...
Thanks in advance,
Ryan
(2,621 Views)
As mentioned before, you should post your request to the downconvert thread.
(2,613 Views)
Hi Ryancola!
To revert a LabVIEW 7.0 VI to LabVIEW 6.0 you will need to perform the following steps:
1) Save the LV 7.0 VI in LabVIEW 7, but select to save for previous version (select 6.1)
2) Open the VI in LV 6.1 and select to save for the previous version (select 6.0)
Please keep in mind however,  that even by performing these steps, there is no guarantee that the Agilent driver will work in LV 6.0.   There were several big changes made in LabVIEW between the versions and this will most likely cause the driver to not function correctly in LV 6.0.
Starla T.
(2,584 Views)
