rs232 so slow, why?
Hello
I'm using a serial Visa at 128000bps. I'm using a handshake thats working like this: I send a char from Labview to the Pic with Visa write then the PIC responds with 5 bytes of data that are read with a Visa read. The problem is that I need  a better sampling rate, right now the PIC is sampling at 96us and Labview is taking 62ms with the write-read-display cycle. So im loosing too much data.
How can I solve this problem?
Thanks in advance.
(5,071 Views)
"write-read-display "
Have you tried without the "display" part?
If it works better you should chase down a producer consumer design pattern to sepearte the I/O from the GUI.
Ben
(5,064 Views)
Hi Ben, thanks for your reply.
The display part is only a wire connected to a waveform chart/graph. Yes, I've tryed without the waveform and the processing time continues above 60ms. There's something to increase the speed of loops?
Thanks.
(5,061 Views)
Hi RPalma,
move the code where you set the baud rate outside the while loop. You'll only have to set this once. Also try to code  a little tidier, use left to right  coding style.  And if you have to read faster, isn't it possible to read more than one sample at a time?
Ton
My LabVIEW Ideas
(5,058 Views)
Hi TonP, thank you for your reply. I will do what you've said about the baud rate. The code is a bit messed up because I had to rearrange to fit in the snapshot.
(5,055 Views)
Hi
I need some help about rs-232 communication. I want to make a vi witch can do this things:
-read a txt file (to simulate a serial port like when the datas are coming)
-write in a txt file or draw in a diagram (or both)
if anybody can help pls HELP ME because im a beginner in this problem.
I already do something but Im not sure that good.
Thx for all.
(5,044 Views)
