rs-223 custom pattern
I need to create custom bit sequence over rs-232 line. Is there a way to make it with USB-232 (SN/778472-01)?
(3,510 Views)
What exactly do you mean by a "customer bit sequence"?
Is it something that will fit within normal serial parameters of start bits, stop bits, and data bits?
(3,509 Views)
No start, stop, parity bits. I need to send only bits I specify.
(3,504 Views)
Accepted by zorandinho
Then no.
You need to use a DAQ card that has timed digital output.  You would build your bit pattern has a digital waveform.
The only other question is what voltage levels you would need for a high bit vs. a low bit.
(3,498 Views)
UART RS-232 requires a start bit and at least 1 stop bit.  But this is usually handled by the transceivers.  They are typically transparent to you or the instrument's processor.
(3,496 Views)
