rotating fill slide
Good Morning (or whatever time of the day it is at your place),
I want to display the data I receive from a 3-Axis acceleration sensor. I'd like to display the 3 values on 3 fill slide. Is it possible to rotate a fill slide by 45°?
If yes: How?
Any help is appreciated
Remember Cunningham's Law
Message 1 of 12
(4,820 Views)
Hi jak,
clear answer: no!
Message 2 of 12
(4,808 Views)
Accepted by topic author PeterFoerster
Hi Jak888,
How about this?
Nitzz
(GIve Kudos to good Answers and Mark it as a Solution if your problem is Solved;))
Message 3 of 12
(4,802 Views)
Hi NitzZ,
that's shifting and not rotating! Smiley Wink
Message 4 of 12
(4,800 Views)
A 3-axis display might be better represented using multiple plots on a 3D graph.
Ian
Message 5 of 12
(4,791 Views)
Shifting will do. Now just tell me, how you did it, please.
Displaying them in a 3D Plot might be better, but I don't really know much about the 3D Plot. I just needed a quick solution, to display them. Later I won't be displaying all 3 axes at the same time.
Message 6 of 12
(4,786 Views)
Hi GerdW,
That was just a random thought:) Just poped in my mind suddenly when I was reading this thread:)
Nitzz
Message 7 of 12
(4,784 Views)
I knocked up a quick demo of the 3d graph - it shows the three axes plus the resultant.
It seems a little buggy somehow - sometimes the lines flicker in and out and depending on the zoom level the visibility changes. This might be something to do with my LabVIEW version (v8.5) and I have a suspicion these graphs have been upgraded in recent years.
However, this should give you the idea....
Ian
Message 8 of 12
(4,780 Views)
Hi Jak,
I am not that good with the 3D plot. Ian has already posted the required explanation on that.:) About the image which i have attached, Its just 3 slide bars used, of which the second one is made to look slanting by covering the upper and lower portions.. You can take a look at the attached vi in my previous post.;)
Nitzz
(Kudos are always Welcome;))
Message 9 of 12
(4,774 Views)
Thats really nice Ian..:) Kudos to you..!!
Message 10 of 12
(4,768 Views)
