rotate image
Hi
I have a narrow but very long image (2047 x 16,000) which I wish to rotate by 90 deg so I make better use of the display screen. Using 'IMAQ rotate' this takes on average 2.5 sec. I then tried 'image_to_array, transpose_array, array_to_image, but this took even longer 3.2 sec. As this is only a transpose operation and and no re-calculation of pixels is required why does it take this long ?
Is there some other way to speed it up.
Willem
PS (Using LabView 7.1 and Vision 7.1)
Message 1 of 17
(6,153 Views)
Hi Willem,
Could you try with this vi...
I don't remember exactly where I found it, but it was on labVIEW Zone, maybe it can be of interest for you..
If so, get inspired !
Epictetus
Antoine Chalons
Message 2 of 17
(6,133 Views)
Hi TiTou,
This looks a lot like an example posted by Christian in the "Picture Control" thread.
http://forums.ni.com/ni/board/message?board.id=BreakPoint&message.id=14&jump=true
Does this look familiar?
Ben
Message 3 of 17
(6,112 Views)
Yep Ben, this is certainly correct... I used it as a source of inspiration a couple of month ago and couldn't remember the thread it was coming from ; so many thanks to Christian.
I hope nobody minds if I use it... 'cause I like it ! Smiley Tongue
Epictetus
Antoine Chalons
Message 4 of 17
(6,106 Views)
I suggest you throw a couple of extra stars on Christian's original post just to be safe. Smiley Happy
And thank YOU for giving me another excuse to plug the "Picture Control" thread. Smiley Wink
Ben
Message Edited by Ben on 01-11-2006 08:21 AM
Message 5 of 17
(6,101 Views)
I wish I could... but I already did give him a 5, when I first saw the vi... Smiley Wink
Epictetus
Antoine Chalons
Message 6 of 17
(6,092 Views)
"I wish I could... but I already did give him a 5, when I first saw the vi...  "
Pay in advance?
Great idea!
Ben
Message 7 of 17
(6,085 Views)
Am I missing the point ?
I meant I gave him stars because I liked his VI the first time I saw it a couple of months ago.
There's no pay in advance, is there ? Or do you you mean I should pay in advance for the next time I'll use one of his VI ?
Well, great idea.. how can proceed to do so ? Smiley Very Happy
have fun and a good day Smiley Wink
Epictetus
Antoine Chalons
Message 8 of 17
(6,081 Views)
TiTou/Ben
Never mind the stars, you seem to rather have missed the point of this question. I have a very large image (2047 X16,000), which I want to rotate by 90 deg. When I try to make the image larger in your vi, it just grinds to a halt well before it reaches the size I want to rotate.
Any other ideas?
Willem
Message 9 of 17
(6,078 Views)
Hi willem,
If you use that example "out of the box" for an image that large, it looks like you will need as much as a Gig or more to handle an image that is 16K X 16K.
Even if you have that much memory to play with LV may have trouble allocating contiguous buffers that large.
You will probably have to "divide and conquer" to win this battle.
I suspect if you grab 2047 X 2047 sections sections, and then rotate each setion (using the method Christian illustrated) you should be able to put the image back together again.
Does that help?
Ben
BTW: The reference to stars is part of a running joke that the "Gold bars" (non-NI) contributors work for stars (not penuts).
Message 10 of 17
(6,012 Views)
