02-25-2014 06:37 AM
ihave designed a vi to find the joint angles using inverse kinematics module in labviwe robotic module. but its givin some error. plz help me to solve the error
06-26-2014 07:06 AM
Can anybody help me in my problem. Actually I have designed a Robotic Arm of my own. I have done the forward kinematics of this arm but it is giving me problem in inverse kinematics. Atually when I try to give a position using start and end transform with some same previous Orientation then it does not calculate but it only calculate with the end effector transform which i generate from forward kinematics by giving some random angles.
But instead the procedure shold be reverse that i should calculate the angles with inverse and put it in forward to check the desired acheived positiion.
