robotics
 ihave designed a vi to find the joint angles using inverse kinematics module in labviwe robotic module. but its givin some error. plz help me to solve the error
(2,668 Views)
Can anybody help me in my problem. Actually I have designed a Robotic Arm of my own. I have done the forward kinematics of this arm but it is giving me problem in inverse kinematics. Atually when I try to give a position using start and end transform with some same previous Orientation then it does not calculate but it only calculate with the end effector transform which i generate from forward kinematics by giving some random angles.
But instead the procedure shold be reverse that i should calculate the angles with inverse and put it in forward to check the desired acheived positiion.
(2,494 Views)
