11-05-2014 11:36 PM
Hi
Does anyone know the wheel base for the
I tried looking on the web, this site and the data sheet and I can't find it.
11-06-2014 02:41 AM
Hi treeewq. Looks like the web page is gone. Cannot find it either?
11-07-2014
09:32 AM
- last edited on
08-11-2026
08:57 AM
by
Content Cleaner
Is this the bot?
http://www.ni.com/datasheet/pdf/en/ds-217
11-07-2014 01:18 PM
YES, the pic on the top 3 wheel
any spec on accuracy of travel?
thanks for prompt reply.
11-07-2014 01:33 PM
What do you mean by travel accuracy?
11-07-2014 09:17 PM
I appreciate your assistance but can more than one answer be answered at a time?
Accuracy: If I want to robot to travel r*w*t where r is radius of wheel, w is the rotational rate and t is the time w is on. how close can it get to the desired pose?
repeatedability: how often or within what range will it reach its final destination?
and
I go through the project wizard and made the standard Starter Kit 2.0 Roaming project as a base project to test the system. I start the app which boots the system and gets the bot going. If I turn the main power off and motor off and then turn them on how do I get the app running again?
another project
I tried to load a simple speed command for a set time in a flat sequence command, that is timed 200ms into the bot and the bot wouldn't respond.Can you offer any suggestions?
When loading a speed command to go straight is it typical that one wheel would differently than the other at startup?
Thanks again for all your help.
11-10-2014
04:57 PM
- last edited on
01-29-2025
01:18 PM
by
Content Cleaner
All of the information that we have will be in the specs sheet for the kit. I would recommend going with the NI LabVIEW Robotics Module as it comes with example programs to help you get started.
The Dead Reckoning.lvproj included in the Robotics Module is a great place to start. Once you have installed the Robot Module. Open LabVIEW, go to help>find examples>Robotics>Starter Kit>Dead Reckoning.lvproj
If you are looking for more information regarding the components of the kit you can contact Pitsco, which makes most of the components for the kit.
-Jayk
