robotics
can we implement pointbug algorithm in sbrio??????
(3,682 Views)
I don't know. Can you?
(3,675 Views)
Accepted by abi_sh
It seems very doable.  Here's a paper that describes the algorithm, and I don't see any reason you couldn't create VIs that do this.
http://uitm.academia.edu/WanAhmadJailaniWanNgah/Papers/866382/A_Simple_Local_Path_Planning_Algorithm...
If you write it (even just a partial implementation), you should consider posting it on the LabVIEW Robotics Code Exchange, so that others can benefit from it...
http://ni.com/code/robotics
(3,652 Views)
is bug algorithm supervised or unsupervised??????
(3,635 Views)
