ring output
I have 3 rings. I use 1 bolean latch when released, when I press the button I want ring 1 to change then the remaining 2 rings change. when false 3 ring can be adjusted freely. I have tried a few case functions structor or slect but it is not my way. Any ideas on this problem?
Thank all.
(2,481 Views)
That calls for an event structure. That will trigger an event when the button is released.
If you don't want a ring to be adjusted, disable the control.
(2,453 Views)
