ring displaying only one value
Hi
I have a ring structure in which i am loading a string array of four variables and its property is strings[]
but while i run the code it is showing only first value
on mouse down nothing is getting changed
on click on ring all values must be shown
(2,739 Views)
Accepted by topic author balakishore
Your ring is an indicator. Make it a control of you want to be able to operate it at run time. (right-click ...change to control)
(2,720 Views)
Thanks for the solution. It works
(2,714 Views)
